HTML Editor adding " to classes
Thread begun 8/08/2011 10:20 am by Joe Lowery | Last modified 8/12/2011 7:10 am by Jason Byrnes | 6327 views | 13 replies |
Joe Lowery
Whenever I assign a style to a paragraph, HTML Editor (version 3.0.2) puts in character entities for the quote marks - in addition to the quote marks already there. So, what should be:
<p class="menuHeading">
becomes:
<p class="&quot;menuHeading&quot;">
What's worse - every time I update the content, another series of character entities is added and now I have:
<p class="&quot;&quot;menuHeading&quot;&quot;">
How do I fix this?
Thanks - Joe
there is formating on the initial value of the HTML editor instance that is converting the double quote character (") to the html entity.
to fix the problem, edit the html editor instance, and re bind the initial value to the corresponding recordset column to remove the formatting.
Joe Lowery
How do I edit the HTML Editor instance to remove the formatting? I opened up the HTML Editor instance, clicked on my preset to edit it and see that, under Formatting, Greek and Latin is set to "No encoding" and Encode HTML Entities is unchecked. I don't see anything else relevant - what am I missing?
you need to re bind the initial value.
click the lightning bolt next to initial value and select the corresponding column from your recordset.
re binding the initial value will remove the formatting.
Joe Lowery
Okay, I got it now - thanks.
Alexneg66
I have the same problem with the quote marks. Unfortunately I cannot re bind the initial value clicking the lightning bolt next, because I get error, as you can see in the "lightning_clicked.png" images.
I have always had this last problem with al version of DataAssit and Dreamweaver. It happens in Detail and Update pages where there are two variable for the ID parameter. You can see the "variable_error.png". So if I modify the value and I click on OK button I get the error from Dreamweaver:
ParamNL is not a valid variable name, it doesn't appear in SQL
Runtime value not found for ParamNL_id variable
This is the source code created from DataAssist:
$ParamNL_id_WADANL_Newsletter = "-1";
if (isset($_GET['NL_id'])) {
$ParamNL_id_WADANL_Newsletter = (get_magic_quotes_gpc()) ? $_GET['NL_id'] : addslashes($_GET['NL_id']);
mysql_select_db($database_connDB, $connDB);
$query_WADANL_Newsletter = sprintf("SELECT NL_id, NL_tit, NL_body, NL_beneficiari, NL_datapartenza FROM NL_Newsletter WHERE NL_id = %s", GetSQLValueString($ParamNL_id_WADANL_Newsletter, "int"));
$WADANL_Newsletter = mysql_query($query_WADANL_Newsletter, $connDB) or die(mysql_error());
$row_WADANL_Newsletter = mysql_fetch_assoc($WADANL_Newsletter);
$totalRows_WADANL_Newsletter = mysql_num_rows($WADANL_Newsletter);?>
When I can, I have to modify manually the code.
I realize these are two different problems but their connection is very important.
Now, what can I do?
Thanks in advance
the screen shots you attached do not include an error when click the lightning bolt for the HTML Editor initial value. please attach the appropriate screen shot.
for the data assist issue, see this post for an explanation of the cause:
showpost.php?p=73308&postcount=3
Alexneg66
Hi Jason,
I have attached two screenshoots I have made on HTML Editor panel.
I don't know what can I do and I don't know if the problem is DataAssist or CSS FormBuilder or HTML Editor or Dreamweaver 5.5
Thanks again
Alex
Alexneg66
... for the problem between DataAssit and Dreamweaver I have followed the advice in the page linked in yor last post.
Thank you, now I can modify the parameter through the recordset panel.
Alex
the error you are getting suggests that there is a problem connecting to the database.
open the database tab, double click the connection and click the test button to make sure the connection is working.
you can fix the quote problem with HTML manually though, by removing the str_replace() function form the initial value
change the code for the initial value from:
<?php echo(str_replace('"', '&quot;', $row_WADANL_Newsletter['NL_body'])); ?>
<?php echo($row_WADANL_Newsletter['NL_body']); ?>
