Problems installing activate without cURL
Thread began 8/07/2011 6:01 am by adrianoluizbauru | Last modified 8/08/2011 7:13 am by Jason Byrnes | 1387 views | 1 replies |
adrianoluizbauru
I'm trying to install more in step 2 of 5 in this error message error
"ERROR: can not activate without PowerCMS cURL installed and functional on your PHP server. Please activate cURL before Attempting to proceed"
has already entered my serial does not go over, and in my dreamweaver serial works correctly.
Please do not know how to proceed in this case.
you will need to enable the curl extension in your php.ini file.
if you get this error on a remote server, you will need to contact the host to have curl enabled.
if it is a local testing server, edit the php.ini file, find the following line:
;extension=php_curl.dll
and change it to:
then restart the server.
