CSS Menu Writer
Thread begun 8/02/2011 8:01 am by eric09141984428691 | Last modified 8/09/2011 12:55 pm by Mike Perry | 4343 views | 6 replies |
eric09141984428691
CSS Menu Writer
It seems that the css menu writer does not work in php pages or does it?
iansheldon422428
Hi Eric,
Yes, it absolutely does and developing within a PHP environment allows you to create database driven menus aswell.
Cheers
Ian
eric09141984428691
reply
if you say it works then im doing something wrong. I input the menu and preview it in the browser and nothing shows.
if you are getting a blank page, it is most likely caused by a php error.
add the following code at line 1 of your page to turn error reporting on:
error_reporting
(E_ALL);
once we know the error, we can troubleshoot the cause.
eric09141984428691
css menue reply
I add the php code you provided and still nothing shows in the php page.
please seand a copy of your page and the css menu writer folder in a zip archive so i can examine the code, also send a link where i can see the issue to troubleshot.
Mike Perry
Eric -- this is probably a stupid question.
Are you using a Web Server (Apache, XAMPP, etc), and do you have PHP installed and running?
Just making sure. . .
