Fly Out Spacing Problem
Hi, Under the Links tab on this simple vertical menu, the children land on top of the mother. What did I do??
drop_down%20problem.html
Thanks!!!! ttt
Thanks!!!! ttt
what version of menu writer are you using?
the CSSMenuWriter/cssmw3/menu.js file does not look right.
Version 1.0.3 - should I delete the menu.js off the server and upload the page again, choosing upload dependant files? Thanks, ttt
In the download center, version 1.0.4 is available for menu writer, uninstall 1.0.3, then install the newer version and recreate the menu, this should generate a new menu.js file, make sure the new menu.js file is uploaded over the existing one.
