Rstrict Access to Pages?
Thread begun 8/01/2011 11:37 am by Cologne | Last modified 8/01/2011 12:51 pm by Cologne | 2344 views | 4 replies |
Cologne
SA2 is installed, and it seems that it dont restrict access to my pages?
I set:
allow if - Session(ID) > 0
allow if - Session(confirm) = 1
allow if - Session(allow) = 1
confirm and allow are 0 in my database but the user gets access? It restricts if the user dont exist.
Whats wrong here?
Please help,
Denis
security assist rules with multiple conditions only need one condition to pass to be considered success ful.
if you need all try conditions to pass, you should create 3 separate rules and modify the page access code to use each one:
if (!WA_Auth_RulePasses("Rule 1") && !WA_Auth_RulePasses("Rule 2") && !WA_Auth_RulePasses("Rule 3")){
WA_Auth_RestrictAccess("login.php");
Cologne
so i better set all to disallow?
or the id at the end?
where is the readon i can insert lots of ifs if it does not work?
strange,
denis
when you multiple conditions in a rule, only ione of the conditions needs to pass fot the rule to be considered true.
if all conditions must pas, you should create a separate rule for each condition and edit the restrict access code like the example from my previous reply.
Cologne
I changed it to disallow.
disallow: confirm = 0
disallow: allow = 0
allow: ID > 0
that works :-)
