Order History & Details pages
Thread begun 7/31/2011 8:06 pm by johna1964 | Last modified 1/13/2012 12:39 pm by afeliksas433126 | 5657 views | 10 replies |
johna1964
How do customers access their specific order history and details?
This may sound like a no brainer, but I really simply don't understand how the user looks at their own order history or even if this is what the purpose is...
How would I allow previous customer to view their own purchase history? I think the UserID in the session variable that allows them to access their history, but what do I need to get them there?
Also, what is the details page specifically for - regarding their personal experience?
As you can see, I'm a little lost...
Thanks!
johna1964
to be able to create an order history page, you first need to force users to login before they can go through the order process.
when the order is stored in the orders table after being processed through the payment gateway, you would need to store the users ID in a column of the orders table to associate the order to the user account of the person that placed the order.
the order history section will have an orders page, this lists each orderr that has been placed, total of the order and other information along those lines, the order detail page would show a listing of the items that where purchased for a specific order.
for details on how to create the order history pages, see the following tutorials on the eCart support page:
Applying Register/Login to your checkout
Automatically populating checkout fields
Creating an Order History page
ecart/
johna1964
Jason,
Hi again...
Let me explain further....
I have already created the forced login from checkout pages...and followed the how to create an order history tutorials.
I am not understanding is how they arrive at the order history page…a link to the page…once they are logged in under their account…in which case they would be redirected to login if they are not logged in already….
In this design, in order to do this, do I a add a dynamic link to css menu writer, for example: Your Account (even though none of my other menu links are dynamic); then select my connection; users table; UserID; UserID;...
I’m not sure how to go about doing this…
What I’m needing is the menu link to force login if they are not logged in or if they are logged in, go to a page (their own account page) where they will be able to link to their customer_order_history.php page…
I’m hoping this is making sense….I just need some guidance…
Also; after running DA wizard to create the order history, should I have used the public results page layout so I can select show 1 column? Then will results run vertical instead of across and off the page?
If so I will need to rerun the wizard and redo the update the server behaviors etc...?
Much thanks!
johna1964
johna1964
Jason,
Pleasant surprise...added the link to the menu...it redirected automatically...should have know that.
I'm sure I'll need you again, but for now I'm okay...
Thanks!
johna1964
johna1964
My question is:
Is there a way to reduce the size of the columns in the customer_order_history.php and customer_order_details.php pages.
WSFE63B9E5-C536-4c25-BA30-5C122914F9ADa.html
These options are not working....
Also; can you use the dw table>delete column option instead of hightlight>delete on both pages?
Thank you again!
johna1964
you should be able to change the width by setting the width on the <th> elements:
for example:
<th class="WADAResultsTableHeader" width="40">DetailID:</th>
yes, the Modify -> Table -> Delete Column option will delete the selected table column.
johna1964
Jason,
Thanks!
I'll give that a try...
Johna
johna1964
Jason,
Hi!
I had to upload to see the changes....one more question here...
I combined the shipping info into one column. I put </br> in between to see if I could put line breaks between the php code. It seems to work in all except Safari (Not sure if it will stay that way),but I was wondering if there is a better way?
In other words, instead of having separate columns for the shipping name, address, city, etc. I combined them into one column...If I don't put the </br> inbetween, they run together...is there a way to do this properly?
Thank you!!
johna1964
properly is a subjective term in this instance.
some people like to have line breaks using <br /> some like to have blank spaces between using &nbsp;
others like to use a combination of the 2.
"properly" is what ever works for you.
johna1964
Jason,
Thanks!
Johna
