Problems after install of powercms
So far I have 2 problem after a brand new install on a clients server.
I uploaded powercms and set up went fine, the first issue was none of the images once logged in showed up. The path show that they are pointing to the admin_cms/images directory. There is not an admin_cms/images directory set up in the software package after extracting the files. I had to copy the images folder from the powercms directory to get them to show up.
Problem 2...
The paths seem to be wrong when editing within the administration. When I click the edit button to initially start editing for content here is the path I get:
contents_update.php?ContentID=1
It is looking for the contents_update.php in the admin_cms/common folder. The file is not located in the admin_cms/common it is in the admin_cms directory.
So I'd like to know what's going on and why the paths are all screwed up on a fresh brand new download of the software.
Unless I missed something, I don't know that I did anything wrong in the process, everything was smooth up to that point.
Any suggestions? I should have to mess with anything in the pre-built solutions as far as I know.
This is with powercms 2.1.1
