Issue with install of PowerCMSBuilder
Thread begun 7/28/2011 6:34 am by emy302298 | Last modified 9/26/2013 9:50 am by Jason Byrnes | 7139 views | 20 replies |
emy302298
I have uploaded all files after setting the initial CMS.
I get this error message with my entire site now down.
lc1986.com
host: godaddy.com
Warning: require_once(../images/installed.png) [function.require-once]: failed to open stream: No such file or directory in /home/content/25/8160825/html/WA_Globals/WA_Globals.php on line 60
Fatal error: require_once() [function.require]: Failed opening required '../images/installed.png' (include_path='.:/usr/local/php5/lib/php') in /home/content/25/8160825/html/WA_Globals/WA_Globals.php on line 60
Please help!
paul283230
Was the problem solved as I am getting the same error problem
I would apprecate getting help on a solution
Regards Paul
craig435405
I have same issue
Warning: require_once(../images/installed.png) [function.require-once]: failed to open stream: No such file or directory in /home/allel465/public_html/mygarage/WA_Globals/WA_Globals.php on line 60
Fatal error: require_once() [function.require]: Failed opening required '../images/installed.png' (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home/allel465/public_html/mygarage/WA_Globals/WA_Globals.php on line 60
toms016390756
Would like to see the solution
the issue was that power store and Power CMS where both installed at the root of the site.
the solution was to install power store to a separate subdirectory.
doug425125
How do you do that?
I'm having similar problems with Power CMS in Design Extender.
This shows Up when I try to edit any of the content:
Warning: require_once(../images/installed.jpg) [function.require-once]: failed to open stream: No such file or directory in /home/jugg2148/public_html/jugglingrealitywebsites.info/WA_Globals/WA_Globals.php on line 60
Fatal error: require_once() [function.require]: Failed opening required '../images/installed.jpg' (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home/jugg2148/public_html/jugglingrealitywebsites.info/WA_Globals/WA_Globals.php on line 60
Any help to solve this would be appreciated..
Have you installed both Power Store and Power CMS to this site?
Design Extender will put the Power CMS at the root of your dreamweaver site.
the solution is to create a subfolder, and put the Power Store files in the subfolder so that they are separated.
