Form Redirect
Thread begun 7/25/2011 11:00 am by ehumbert267432 | Last modified 7/27/2011 9:32 am by MikeyT | 5797 views | 9 replies |
ehumbert267432
Form Redirect
I've created a form to upload files to a specified directory on the server. This form is a pre-existing form, and it works, especially since I used Form Builder to specify how the uploads were handled. All works well, and I used the pre-existing form because when I try and build it from scratch (the page layout was built using a Dreamweaver template) it seems to force the form to drop about 10 lines below the existing text. Hand creating the form works without the big gap.
So, the form is uploading the files quite satisfyingly. Now, I need to put in a redirect when completed, so that the customer will get a message thanking them. Message page is built, but I can't figure out how to redirect to the thank-you page. Any thoughts?
Gene
Do you send an email or Insert into a database with the form? If so you can add a redirect in the email or insert record server behavior.
If you are just uploading a file and aren't using the data in any other way, then you could manually add redirect code like:
if (isset($_POST("submitbuttonname"))) header("location: thankyoupage.php");
ehumbert267432
Got that part, but....
Now the client wants the names of the files that were uploaded listed in the email. I used variables (upload1, upload2, etc) as the names used by the file upload that Form Builder offers. Can I use them somehow to add to the email generated? I'm new at this stuff, so I don't know quite what I'm doing here.
Gene
ehumbert267432
also...
After posting the first message, I dug into the email utilities offered and figured out the redirect, and it's working fine. I need to change the format of the email so that it doesn't send all the info that the template provides. They aren't interested in the subheader section, so I need to remove it. Is that a problem?
Gene
Not a problem, just update the associated email template file and you can remove the code that automatically adds all of the form elements and replace it with a custom page that only shows what you want in the style that you want.
MikeyT
Ray, is it possible to trigger a thankyou.php page upon form submit without the need for an email or what Universal Email offers? My form action is a client supplied url that captures the text field information so I can't use <?php echo(htmlentities($_SERVER["PHP_SELF"], ENT_QUOTES)); ?>"> - or at least I think I can't since the url needs to be the form action value.
The form functions fine as is, but when you submit information you're directed to the url which is just a blank page. So the user experience is lacking.
I wasn't sure if there was a php solution for this scenario and whether or not I should just use a jQuery modal window to serve up a confirmation message instead.
Sorry, don't mean to hijack this thread.
Is the action page a php page? If so you can update the code on the blank page to redirect to another page like:
Edit/Delete Message
MikeyT
I'm not sure actually. I was given names and values to use for the form fields, as well as two hidden fields, and the following url to use as the form action (altered for anonymity)
altered.WebToLead?encoding=UTF-8
When you submit the form, you're taken to this page but its a blank page - assuming because the form info is being inserted into the lead retrieval system. No actual page exists.
I've confirmed with the client that all is working properly on their end.
Maybe there is another field name that works with that system that allows you to set the redirect page? I'd ask the people that gave you the field names to use if there is a field name you can add to set a page to display on completion.
MikeyT
Thanks for your help, Ray.
Problem solved: I was overlooking one of the hidden fields that is to be used for a return url. Assigning the value to my confirmation page did the trick.
