Need a hand getting started with Search page
Thread begun 7/25/2011 8:23 am by A Sound Design | Last modified 7/26/2011 10:22 am by Jason Byrnes | 5878 views | 13 replies |
A Sound Design
I've been trying to follow the tutorial but am finding it hard to adapt to my own site.
I would like to create a search page to return results from a links directory database. What I want is so that visitors can enter a search term, eg. photographer, it will return only those records that are related to photography. I have tried using a Db field called Keywords and set the search wizard to target that but it just displays all records in the Db.
My code is:
//WA Database Search (Copyright 2005, WebAssist.com)
//Recordset: rsItems;
//Searchpage: search.php;
//Form: frmSearchForm;
$WADbSearch1_DefaultWhere = "WHERE 0 <> 0";
if (!
session_id()) session_start();
if (isset(
$_POST["button2"])) {
$WADbSearch1 = new FilterDef;
$WADbSearch1->initializeQueryBuilder("MYSQL","1");
//keyword array declarations
$KeyArr1 = array("Keywords");
//comparison list additions
$WADbSearch1->keywordComparison($KeyArr1,"".$row_rsItems['Keywords']  ."","OR","Includes","%20AND%20","%20OR%20","%22","%22",0);
//save the query in a session variable
if (1 == 1) {
$_SESSION["WADbSearch1_search_results"]=$WADbSearch1->whereClause;
else     {
//get the filter definition from a session variable
if (1 == 1)     {
    if (isset(
$_SESSION["WADbSearch1_search_results"]) && $_SESSION["WADbSearch1_search_results"] != "")     {
$WADbSearch1->whereClause = $_SESSION["WADbSearch1_search_results"];
    else     {
$WADbSearch1->whereClause = $WADbSearch1_DefaultWhere;
  else     {
$WADbSearch1->whereClause = str_replace("\\''", "''", $WADbSearch1->whereClause);
$WADbSearch1whereClause = '';
This looks wrong... I think this:
should be:
$WADbSearch1->keywordComparison($KeyArr1,"Keywords"
A Sound Design
should be:
Didn't make any difference changing that.
Can you upload a copy of your search page and your results page? If I can look at both I'll be able to spot any issues.
A Sound Design
I fiddled around and tried changing stuff since I last posted.
Try changing:
$WADbSearch1->keywordComparison($KeyArr1,"Keywords",
$WADbSearch1->keywordComparison($KeyArr1,"".$_POST['Search'] .""
A Sound Design
That gives an error:
Parse error: syntax error, unexpected T_CONSTANT_ENCAPSED_STRING in C:\xampp\htdocs\affiancedv2\search_results.php on line 24
I understand that you're trying to help but I don't understand why there needs to be a lot of fiddling. I bought Data Assist as it promised results without a load of coding. I cannot understand why it does not work by just running the DA Search Wizard. What I need is a simple search page, where a customer can type in a search phrase, eg. video production, and get a list of all records that are related to that. I only used a keywords field in the DB as I thought this might be a more targetted way of doing it. If there is a better way I'd be happy to know. Thanks.
This is the correct way of doing it. The only problem was that you bound the search value to the recordset field instead of the form field. I made a mistake when I suggested the first correction which I apologize for. It is just a small tweak because you selected the wrong value when setting up the search.
If you attach a copy of the code or show me the line of code that is giving the error I can point out the problem and we can get it fixed.
If you want to delete the code an re-apply the search it would have worked properly if you bound the search value to the form field instead of the recordset field.
A Sound Design
Ok, I've attached the files.
line 24:
$WADbSearch1->keywordComparison($KeyArr1,"".$_POST['Search'] ."" "OR","Includes","%20AND%20","%20OR%20","%22","%22",0);
is missing a comma, it should be:
$WADbSearch1->keywordComparison($KeyArr1,"".$_POST['Search'] ."", "OR","Includes","%20AND%20","%20OR%20","%22","%22",0);
