SQL Error on using CMS History (Powerstore 4.5)
Thread begun 7/24/2011 10:14 pm by CheopisIV | Last modified 7/25/2011 7:01 am by Ray Borduin | 1376 views | 1 replies |
CheopisIVBeta Tester
I was playing in the CMS and was getting an error when trying to use the 'History' feature;
Warning: require_once(../HTMLEditor/WARichEditorPHP.php) [function.require-once]: failed to open stream: No such file or directory in /xxxxxx/admin/contenthistory_results.php on line 5
Fatal error: require_once() [function.require]: Failed opening required '../HTMLEditor/WARichEditorPHP.php' (include_path='.:/usr/lib/php5') in /xxxxxx/store/admin/contenthistory_results.php on line 5
I noticed I didn't have the HTMLEditor folder so I commented out the 5th line
<?php require_once("../HTMLEditor/WARichEditorPHP.php"); ?>
changed to
<?php //require_once("../HTMLEditor/WARichEditorPHP.php"); ?>
and everything appears to be working fine. Just wondering if the missing files are required for anything or if the above is just an extra piece of legacy code that can safely be omitted?
That is a piece of legacy code that can be safely deleted or commented out. We apologize for the oversight, but simply removing the code is the correct solution as you have done.
