error sending password
Thread begun 7/24/2011 1:18 pm by arteydiseno381654 | Last modified 7/29/2011 8:25 am by arteydiseno381654 | 3554 views | 6 replies |
arteydiseno381654
test link: recuperar-password.php
When sending mail with the password the following error
Warning: Missing argument 6 for WA_SecurityAssist_Definition(), called in /home/nigmaage/public_html/cliente/soccerland/admin/recuperar-password.php on line 75 and defined in /home/nigmaage/public_html/cliente/soccerland/webassist/security_assist/mail_php.php on line 34
Warning: session_start() [function.session-start]: Cannot send session cookie - headers already sent by (output started at /home/nigmaage/public_html/cliente/soccerland/webassist/security_assist/mail_php.php:34) in /home/nigmaage/public_html/cliente/soccerland/webassist/security_assist/mail_php.php on line 239
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /home/nigmaage/public_html/cliente/soccerland/webassist/security_assist/mail_php.php:34) in /home/nigmaage/public_html/cliente/soccerland/webassist/security_assist/mail_php.php on line 239
Warning: Cannot modify header information - headers already sent by (output started at /home/nigmaage/public_html/cliente/soccerland/webassist/security_assist/mail_php.php:34) in /home/nigmaage/public_html/cliente/soccerland/webassist/security_assist/helper_php.php on line 275
thanks for your help
The real error is the first one:
The other errors only happen as a result of the first error. To debug the first error I'd like to see the two files mentioned in the error:
and
If you can zip and attach a copy of those two files I should be able to give you instructions on how to correct the problem.
Do you have an older version of Universal Email installed (pre v4)? That could be the cause of the issue, but if you send me those two files I'll figure out how to correct it.
arteydiseno381654
I am using SecurityAssist 2.0.2 and I have Universal Email 4.0.1
I attached the files
Thanks!
Update line 75 of recaperar-password.php from:
$WA_MailObject = WA_SecurityAssist_Definition("yourmailserver.yourdomain.com","25","","","");
$WA_MailObject = WA_SecurityAssist_Definition("","25","","","","");
I'm not sure what the cause of this is, but that should solve it. Did you use an encrypted password? What type of encryption? I'll see if I can reproduce the problem and get a bug logged.
arteydiseno381654
I updated the line but the error continues. I am using md5 to encrypt the password
did you copy and paste the updated code, or did you just remove the "yourmailserver.yourd omain.com" from your code.
look closely at the updated code, and you will see that ray also added an extra parameter to the function call. if you only removed "yourmailserver.yourd omain.com" from your code, you will still have 5 parameters:
$WA_MailObject = WA_SecurityAssist_Definition("","25","","","");
instead of the 6 that are needed:
arteydiseno381654
solved, perfect, thank you very much, but it would be good then repaired extension SecurityAssist 2.0.2
