Backing Security Assist out of PowerCMS
Thread begun 7/24/2011 9:22 am by rik.forgo | Last modified 7/25/2011 6:24 am by Ray Borduin | 1739 views | 1 replies |
rik.forgo
Hi folks, we unsuccessfully tried an installation of SecurityAssist on our site. Turns out that we don't really need it yet and would like to back it out of the site code. PowerCMS was working fine until the SA installation. Now we get this error:
Warning: require_once(/webassist/security_assist/helper_php.php) [function.require-once]: failed to open stream: No such file or directory in /home/****/****.org/powercms/admin_cms/index.php on line 5
Fatal error: require_once() [function.require]: Failed opening required '/webassist/security_assist/helper_php.php' (include_path='.:/usr/local/lib/php:/usr/local/php5/lib/pear') in /home/****/****.org/powercms/admin_cms/index.php on line 5
If we want to back SA out of the code and get everything back to where it was, what do we have to remove from what files?
You could probably just overwrite your files with the original powerCMS files. What you would have to remove depends on what you added, so it is hard to answer that question.
From the looks of this particular error you may just need to delete line 5 of admin_cms/index.php.
