Administrator Account creation
Thread begun 7/24/2011 3:28 am by info412429 | Last modified 7/26/2011 11:06 am by Jason Byrnes | 4476 views | 7 replies |
info412429
Hi support team, how do I edit the Administrator profile so that the "Contents" section will be hidden.
I just created an administrator account, but i have only "Settings" and "Design" sections hidden.
Please help me out.
Thx.
You would have to do this by hand...
Open the file: /webassist/plugins/admin_menu/menu.php
And copy and paste the code that hides the Settings and Design sections to hide the Contents section as well.
info412429
Thx for that Ray. I have done it.
Now, I need to create a menu that will be linked to an external site, so that when its been clicked it opens a page which is not within powerstore, but it will open within same window.
Also I need to create a link on the footer, for example; "Powered by info412429". Now when users click on this link, it should open an external website in a different window. Also I will need to display this link at da far right side of the footer.
Help me out, please.
Thx
You would have to update the files to add those links.
/webassist/plugins/main_menu/menu.php
and
/webassist/plugins/cms_templates/footer.php
info412429
and
Thx Ray, I have been able to do the menu link, but I cant seem to be getting it right with the footer. I guess its because I dont know much about php yet. Can you please show me where I need to enter my values; "Powered by KingzGold Technologies", with the link www.kingzgold.com, that will be opened in a new window when clicked? I wish you can me fix this into the footer code below for me now....
Thx.
<?php require_once('../../../Connections/PowerStoreConnection.php'); ?>
if (PHP_VERSION < 6) {
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
mysql_select_db($database_PowerStoreConnection, $PowerStoreConnection);
$query_CMStoRS = "SELECT C2.ContentGroup, C2.ContentPageSetOrder FROM ps4_contents AS C1 LEFT OUTER JOIN ps4_contents AS C2 ON C2.ContentPagesetParentID = C1.ContentID WHERE C1.ContentGroup = 'Footer Pages' AND C2.ContentPageSetOrder IS NOT NULL GROUP BY C2.ContentPageSetOrder ORDER BY C2.ContentPageSetOrder DESC";
$CMStoRS = mysql_query($query_CMStoRS, $PowerStoreConnection) or die(mysql_error());
$row_CMStoRS = mysql_fetch_assoc($CMStoRS);
$totalRows_CMStoRS = mysql_num_rows($CMStoRS);
<html>
<head>
</head>
<body>
<ul>
$row=0;
<?php do { ?>
$row++;
$class="";
if (!isset($pastFirst)) {
$class = "first";
if ($row==$totalRows_CMStoRS) {
$class = " ";
$class .= "last";
$pastFirst=true;
<li <?php if ($class!="") { echo('class="'.$class.'"'); } ?>><a href="../../../page.php?Footer Pages=<?php echo $row_CMStoRS['ContentPageSetOrder']; ?>"><?php echo $row_CMStoRS['ContentGroup']; ?></a></li>
<?php } while ($row_CMStoRS = mysql_fetch_assoc($CMStoRS)); ?>
</ul>
</body>
</html>
mysql_free_result($CMStoRS);
add the link just after this line:
as an li tag:
<li><a href="http://www.kingzgold.com">Powered by KingzGold Technologies</a></li>
info412429
as an li tag:
Thx Jason.
I have also realised that although I have blocked the "Contents" menu from showing in the admin panel to my client, each time I log in with an admin account, the Contents section is active at the front end.
How do I deactivate that?
On my homepage though, I have the text of the featured products and the welcome section too down. how do I bring it up to the middle?
And at the right end too, the pod box size has reduced. Its not fitting to the page. can you please check and help me to get it even.
Thx
