wagmp_map_1.php gets overwritten
Thread begun 7/23/2011 2:00 am by rhys.parry425426 | Last modified 7/25/2011 5:44 am by Ray Borduin | 1415 views | 1 replies |
rhys.parry425426
Hi
I have successfully used the documentation to change the zoom factor. It works well but if you use the EDIT wizard it seems that the wizard overwrites the file. For example if I set the zoom up (in my case 3 places only) in the .php file, store it and test then I get the expect result. If I then use the wizard to, say, change the info box to custom and save I lose all the manual changes.
Any suggestoins please?
There is no solution for this... your best bet is to save a backup of the file once you have made hand edits.
The wizard is not able to identify what you have and haven't edited by hand and it will always regenerate the file once you make changes.
