sessionid not clearing
Thread begun 7/22/2011 11:26 pm by CraigR | Last modified 7/25/2011 1:16 pm by Ray Borduin | 3231 views | 5 replies |
CraigRBeta Tester
i notice this when testing several transactions in succession.
if i make a successful transaction my sessions are cleared and the cart is emptied. However, if i add more items to the cart and make a second purchase very soon afterwards, the session_id which is stored in the orders table as Orderreferenceid is the same as the previous one.
You should be able to add code to the top of your checkout success page to regenerate the session id:
session_regenerate_id();
CraigRBeta Tester
Hi Ray.
I already have the folowing code at the bottom of my checkout success page.
//initialize the session
if (!isset($_SESSION)) {
session_start();
// Unset all of the session variables.
$_SESSION = array();
// If it's desired to kill the session, also delete the session cookie.
// Note: This will destroy the session, and not just the session data!
if (isset($_COOKIE[session_name()])) {
setcookie(session_name(), '', time()-42000, '/');
// Finally, destroy the session.
@session_destroy();//This will also clear the session cookie which forces a new session ID to be generated.
Just wondered why sessionid was stil intact after this point, as the cart content is cleared
session_destroy will remove all session variables, but won't actually regenerate the session id.
If you want to remove all variables from session and change SID first use
session_destroy();
if you do destroy first then regenerate_id your SID will not change.
I found this on the php site: function.session-destroy.php
CraigRBeta Tester
Thanks Ray.
My client has now decided they don't want the customer to be logged out after a successful transaction.
Whats the easist way to retain the accountid session whilst clearing the rest.
Probably save it before clearing the session, then clear the session and then re-set it:
$LoginID = $_SESSION['UserID']
session_destroy();
session_start();
$_SESSION['UserID'] = $LoginID;
