PS 4.5 Admin area themes edit error
Thread began 7/22/2011 3:10 pm by info385819 | Last modified 8/23/2011 8:51 am by Jason Byrnes | 2046 views | 3 replies |
info385819
When admin attempts to edit an existing theme the user is getting this error:
Warning: fopen(../../themes/temp_editing/css/configurable.css) [function.fopen]: failed to open stream: No such file or directory in /home/content/58/8127658/html/webassist/plugins/styler/styler.php on line 98
Warning: filesize() [function.filesize]: stat failed for ../../themes/temp_editing/css/configurable.css in /home/content/58/8127658/html/webassist/plugins/styler/styler.php on line 99
Warning: fread(): supplied argument is not a valid stream resource in /home/content/58/8127658/html/webassist/plugins/styler/styler.php on line 99
Warning: fclose(): supplied argument is not a valid stream resource in /home/content/58/8127658/html/webassist/plugins/styler/styler.php on line 100
Warning: simplexml_load_file() [function.simplexml-load-file]: I/O warning : failed to load external entity "../../themes/temp_editing/theme_settings.xml" in /home/content/58/8127658/html/webassist/plugins/styler/styler.php on line 103
Fatal error: Call to a member function asXML() on a non-object in /home/content/58/8127658/html/webassist/plugins/styler/styler.php on line 116
This is probably due to file permissions issues.
Try this:
1) delete the webassist/themes/temp_editing folder
2) use an ftp program like filezilla to update the permissions of the webassist folder and all of its subfolders and files to: 755
3) replace the admin/common/properties.php page with the one attached
4) replace the webassist/plugins/styler/styler.php page with the one attached
Then try it again and see if it works.
properties.zip
styler.zip
Web Designer Troy
500 Internal Error after adding custom template
I performed the above steps but I'm still getting the same error. I'm using PowerStore 4.5.
