FB plug into CSSFB Email
Thread begun 7/22/2011 1:37 pm by Cologne | Last modified 7/23/2011 10:43 am by Ray Borduin | 3129 views | 5 replies |
Cologne
it would be cool, to be able to use a plug-in in the CSSFormBuilder Email wizzard.
I always use the DW template to create my messages.
Now I tried to put in a FB plug-in (a page that carries the design), but that does not work cause of missing <head> tag or something.
is there a work around?
Cheers
Denis
It should work... what is the exact error message? Maybe send a zipped copy of the pages and a description of what happens and the exact error and I can help figure it out.
Cologne
Hey Ray,
files are attached.
The waue_sendmail_1 file must be copied in the webassist folder ;-)
Denis
Can I see a copy of the page you are trying to add the plugin to? This might be a misunderstanding of how plugins work, but I'd like to see the page you are adding the plugin to.
Cologne
Hi Ray,
I like to ad a plugin at this page: "waue_sendmail_1.php" the page that CSSFB createswhen ading the email-text via DW.
When the wizzard opens, down in the window I can choose, Editor or Dreamweaver. I choose DW and that page "waue_sendmail_1" opens to create my email text. (see image 1 the little green DW button).
And there I like to ad a plug in with my designd email-text, so I can change it without opening the email wizzard again.
Denis
You shouldn't use a plugin for this. Just check the box "create a file for my body" in the UE wizard and select the page.
Then you can update that page as the email body without needing to enter the wizard in the future.
