Fatal Error
Thread begun 7/22/2011 11:30 am by Cologne | Last modified 12/20/2011 6:58 am by Cologne | 7582 views | 14 replies |
Cologne
Fatal Error
when I create pages from the them I get this error:
Fatal error: Allowed memory size of 67108864 bytes exhausted (tried to allocate 40961 bytes) in /www/htdocs/w00d9940/webassist/framework/framework.php on line 32
I tried this Known Issues "Framework Builder: Support Fix - Memory errors in PHP when creating themes (6.67 Kb)" but this does not help :-(
what can I do?
Denis
Most likely you have a recursive page reference... maybe a plugin that has a plugin that refers to the page. Or a page that refers to itself as its theme. If you attach a copy of the page you are working on I can probably find the recursive reference.
Cologne
hi,
here are the pages.
its just a little layout. the dw tempalte, the FB template and the 4 pages.
cheers
Denis
This is probably an error in the extension that it happened in the first place, but the issue is that the pages are set to be derived from a theme and the theme is set to the page itself creating an endless loop.
For instance on page1.php line 9 it shouldn't have "page1.php" it should have "test.dwt.php" specified as the theme page... same issue on the other three pages. This may be an issue with the create page from theme command of some sort.
Cologne
ok, now it works. but, how should i do it that it is creating the code right?
page1.php
It appears to be the new page from theme command. You may need to edit the theme setting and reset the theme after creating the page for now. I'll log it as a bug and try to get it updated in the next release.
Cologne
I did not understand that.
I create a DW template ---> convert it to a FrameBuilder Theme ---> create page with theme.
then I go back into my DW template and set the links to the FB created pages.
what do I have to reset?
Denis
I'm thinking you may need to double click on the theme server behavior and reset the theme design page, since that appears to be what is set incorrectly.
Cologne
hmm, this does not work.
or I dont understand what you mean with "reset" :-(
I double click on the page theme server behavior. there i can see only the trigger set to always and click ok. but nothing changes.
I guess you'll have to manually update the code for now to point to the correct theme design.
I've reported this issue to our QA team and we'll get it logged as a bug and have someone work on it for the next dot release.
