DA Search not finding exact phrases
Thread begun 7/21/2011 10:24 am by ccooper309155 | Last modified 7/21/2011 11:22 am by ccooper309155 | 1735 views | 4 replies |
ccooper309155
I've recently implemented DA search on a site and it works except for exact phrases.
For instance, if I search using "Light Jungle", the results return an empty recordset even though that phrase is in the database.
If I search using Light Jungle I get every record that has Light or Jungle in it.
If I search using Light, Jungle I get every record that has Light and Jungle in it.
I have implemented DA Search many times before and not had this problem.
Using ASP VB and MS-SQL.
Here is the code from the results page:
'WA Database Search (Copyright 2005, WebAssist.com)
'Recordset: rsRuleBook;
'Searchpage: ASL.asp;
'Form: frmSearch;
dim WADbSearch1_DefaultWhere
WADbSearch1_DefaultWhere = ""
if (cStr(Request.Form("WADbSearch1")) <> "") then
dim WADbSearch1_whereClause, WADbSearch1_dateSeparator, WADbSearch1_wildCard
WADbSearch1_wildCard = "%"
WADbSearch1_dateSeparator = "'"
if ("SQL SERVER" = "ACCESS") then
WADbSearch1_dateSeparator="#"
end if
if ("SQL SERVER" = "ORACLE") then
WADbSearch1_dateSeparator="TO_DATE('"
end if
if ("SQL SERVER" = "MYSQL") then
WADbSearch1_dateSeparator="MYSQL"""
end if
'keyword array declarations
Dim WADbSearch1_KeyArr0
WADbSearch1_KeyArr0 = Array("Chapter","RuleNum","RuleCopy")
'comparison list additions
WADbSearch1_whereClause=BuildKeyword(WADbSearch1_KeyArr0,"" & cStr(Request.Form("SearchBox")) & "","","Includes",",%20","%20","%22","%22",0,WADbSearch1_wildCard,WADbSearch1_dateSeparator,WADbSearch1_whereClause)
if (1 = 1) then
Session("WADbSearch1_ASLRB_Searched")=WADbSearch1_whereClause
end if
else
if (1 = 1) then
if (cStr(Session("WADbSearch1_ASLRB_Searched")) <> "") then
WADbSearch1_whereClause = cStr(Session("WADbSearch1_ASLRB_Searched"))
else
WADbSearch1_whereClause = WADbSearch1_DefaultWhere
end if
else
end if
end if
What is the problem?
Any help much appreciated!
The solution is probably to change the implied OR from the default which is a space. In the code it would be this line:
WADbSearch1_whereClause=BuildKeyword(WADbSearch1_K eyArr0,"" & cStr(Request.Form("SearchBox")) & "","","Includes",",%20","%20","%22","%22",0,WADbSe arch1_wildCard,WADbSearch1_dateSeparator,WADbSearc h1_whereClause)
WADbSearch1_whereClause=BuildKeyword(WADbSearch1_K eyArr0,"" & cStr(Request.Form("SearchBox")) & "","","Includes",",%20","%20OR%20","%22","%22",0,WADbSe arch1_wildCard,WADbSearch1_dateSeparator,WADbSearc h1_whereClause)
ccooper309155
Thanks, Ray but that did not work.
Your suggested code returned errors of: Microsoft VBScript compilation error '800a03ee'
when I searched either "Light Jungle" or Light OR Jungle.
The problem is that if you copied and pasted this forum is adding spaces into the code to make it wrap. Try this:
WADbSearch1_whereClause=BuildKeyword(WADbSearch1_KeyArr0,"" & cStr(Request.Form("SearchBox")) & "","","Includes",",%20","%20OR%20","%22","%22",0,WADbSearch1_wildCard,WADbSearch1_dateSeparator,WADbSearch1_whereClause)
ccooper309155
You're probably right - I did copy and paste.
But your theory led me to the solution.
I am now using + for AND and , for OR
Thus Light+Jungle is now returning all the records which contain both Light and Jungle
Light,Jungle is returning all the records which contain either Light or Jungle
And "Light Jungle" is returning all the records that contain that exact phrase.
Thanks for your prompt help!
