CSS Form Builder Duplicate Images
Thread began 7/21/2011 8:26 am by john70964 | Last modified 7/21/2011 10:27 am by john70964 | 887 views | 2 replies |
john70964
I wish to be able to upload several main images and the thumnails for these per form.
Looking at Step 1 "Configure file upload settings" if a file of the same name is sent I wish to "Rename New File".
I cannot see what to rename to
I cannot see how this is carried out.
Can anyone please explain.
Many Thanks
John
The default will leave the image name as it was uploaded if there isn't already an image with that name.
The rename option can be set to any string, but has two tokens [NewFileName] and [Increment] so that if you left the default the first upload would be named: "MyImage.jpg" and if you tried to upload it again it would be named: "MyImage_2.jpg".
You can remove the underscore or adjust the new image syntax as you see appropriate.
john70964
Thank you Ray for the very clear answer.
Regards
John
