Bug shows prior version where current version is in use.
Thread began 7/21/2011 8:12 am by neo314 | Last modified 7/21/2011 12:34 pm by neo314 | 951 views | 2 replies |
neo314
I found on a template page in DW3 (and I don't think that the fact it was a template is involved) a minor bug.
I created some SA show regions, so the page header contains:
<?php require_once( "../webassist/security_assist/helper_php.php" ); ?>
Then I add a restrict access to page behavior and it comes out like this:
if (!WA_Auth_RulePasses("admin")){
WA_Auth_RestrictAccess("../admin/index.php");
When that happens, my Server Behavior window shows all the SA behaviors as having the error of "Prior Version" which it isn't. When I double click on one of the behaviors to fix it, the code is modified to look like this:
(If anyone else sees this, just remove the second include reference, or modify the code to look like this (separate code blocks for the include and the behavior code):
This appears to be a bug where it won't recognize the include file is on the page when it is contained inside the same code chunk.
The solution is to add the :
in between the require_once and the rest of the script. We'll log this as a bug to either make sure we always add the include in a separate code chunk or recognize it when it isn't and try to get it resolved sometime soon.
neo314
That would work as well. Just wanted to report the bug.
