Zoom not working after recipe and forum post
Thread begun 7/21/2011 6:12 am by mpolly380889 | Last modified 7/26/2011 6:27 am by Ray Borduin | 4112 views | 7 replies |
mpolly380889
I am trying to get the zoom level a little closer in and tried the recipe and instructions here with no luck. showthread.php?t=19936&highlight=zoom
Here is a link to the issue: 3sjse9k
I attached the the map code for review. What am I doing wrong?
Search the script for:
map.setCenter
it appears there are a few places you missed and it wasn't updated.
mpolly380889
No such luck...
I am not sure I understand where you are referring to?
I found two additional instances of map.setCenter(new GLatLng(30, -98), 3); and changed it to map.setCenter(new GLatLng(30, -98), 12); and now it is plotting the map but then changes location to outside of Texas? If I refresh the page it eventually shows up correctly but the first visit to the page is a problem. Attached is the latest file for review.
Also, this appears to be a problem in Firefox 5.0...in IE it seemed to switch from the wayward Texas location back to the correct Florida location.
Is there a URL where I can view the problem? I can't spot the issue easily by reviewing the code out of context.
mpolly380889
Post Link
Yes, original post: 3sjse9k
It appears the geocache page isn't working correctly at: /promaps_geocache_php.php
I'll open a support incident so that one of our engineers can look into this with you directly. We'll either need to work with you over the phone or get ftp access to your server to test and debug a solution.
mpolly380889
No support ticket?
Where do I go to start getting help on the support ticket? I logged into my account and click on support an there is no open tickets? I really need to get this figured out. Please advise.
It appears your incident wasn't created properly. I apologize. I have added a ticket now that should show up.
