Crop from Center
Thread began 7/20/2011 1:30 pm by Cologne | Last modified 7/21/2011 9:40 am by Cologne | 937 views | 2 replies |
Cologne
Crop from Center
i love that crop from center, but is it somehow possibel to resize the image befor it crops from center, so the visitor can see a little from the image.
if its from the big image only, you mostly can see nothing :-(
Cheers
Denis
That should be what it does automatically.
The crop from center should essentially re-size the image to either fit the full height or the full width depending on the original image dimensions. Then it will crop either the width or the height that overlaps.
Do you have a sample image and cropped version you can show me so that I might better understand what you are looking at and maybe what you were hoping to see instead?
Cologne
ah,
ok, that works.
so, I give the image the size I want in code view. and then I put image resizer over it, ok.
thanks!
