Quick Question - Checkout Wizard
Can I use Dreamweaver Spry Validations Widget to validate the text fields and checkbox?
Thanks,
johna1964
Thanks,
johna1964
yes, if you select a form element, the go to Insert -> Spry -> Spry <element type> (where <element type> is the same type of element you have selected)
it will convert that element to a spry element.
Jason,
Perfect!
Again, thanks so much!
Johna
