Image update not working in Update Form when file is used with the Framework
Thread begun 7/20/2011 8:43 am by Nico | Last modified 7/20/2011 11:54 pm by Nico | 1874 views | 2 replies |
Nico
Hi.
I am having a strange issue. When I use an update form (created with "Datassist extension") by itself (directly) the form works great. Uploads an image if I declare a new image or leaves the old image if I don't submit a new image file.
The problem is that I am using (the file that contains the update form) with the "Framework extension" and the image is not being updated. The image field in the database becomes empty.
Conclusion. Using the file form directly works great, including it with the "Framework extension" inside another file the image is not being updated (in fact it's being removed form the database). The rest of the fields are updated correctly.
Using windows XP - DW CS5.5
Thank you in advance
the image upload behaviors are set to use the current page submit triggers, the update is set to use the any form post trigger.
change the image upload behaviors to use the any form post triggers.
Nico
Worked!
Thank you very much
