Storing last user login date
Thread begun 7/19/2011 11:40 pm by info266692 | Last modified 7/25/2011 7:50 am by Ray Borduin | 9846 views | 7 replies |
info266692
I have searched throughout the URSP Forum to find out how you can store the last login date when a User complete the login page; and I couldn’t find any relevant information.
I have created a column in the users table to store the login date (login_date, type datetime) is this the right attribute for storing date and time in SQL?
I also made countless attempts into the page users_LogIn.php by inserting various system to store the last user login date in the column login_date of the users table, but nothing ever worked.
Can you help me in resolving this issue? My database skills are a bit more than basic and my coding experience is slightly more than of a novice.
I found Web Assist extensions quite liberating by making accessible PHP scripts and creating new dimensions in web design beyond the plain HTML and Java Scripts. Thanks for your great extensions.
Alfredo
This sort of modification is not supported in the Solution packs, I can give you steps to follow, but cant really offer more help if you are not able to get this working.
first, open the bindings panel and expand the session collection, make sure there is a session in the bindings panel named UserID, if its not there, click the plus button , selct Session Variable and name it UserID to createt the binding.
now, on the login page, locate the two lines that redirect to the users_Profile page:
"successRedirect" => "users_Profile.php",
and change them both to:
"successRedirect" => "",
Now go to the server behaviors panel and click the plus button, select Data Assist, updare record, single record Update
in the update record dialog box, select the users table, set the key column to UserID
click the lightning bolt next to value and selcet the UserID session variable binding.
set the redirect to go to the users_Profile.php
on the second step, select your login_date column and enter the following code for the value:
[php]
<?php echo (date("Y-m-d h:m:s")); ?>
[php]
in the code, you will need to move the update record code so that it comes after the login user code.
info266692
Dear Jason,
I have made those changes, following your directions, to the user_LogIn.php page and I'm getting an error "Incorrect datetime value ....". In actual fact the page showing the error displays the right date and time (I had to change the low cases to capital in your code snippet "[php]<?php echo (date("Y-m-d h:m:s")); ?>[php]" to "[php]<?php echo (date("Y-M-D h:m:s")); ?>[php]".
I figure the error is due to the fact that the Update Record Code is not updating the database or maybe is not positioned properly after the login user code.
I'm designing a web site for a blind person who has a number of clients to administer and check out if they make use of the site. I know that is possible to create some Clients monitoring systems with other tables and query pages but this will complicate the Administration area. I really would like to keep it simple and record the date the Client has logged in.
I understand that this bit of coding is not supported by WA with URSP, however throughout this forum there many bits of codes suggested in other applications which goes well behind what is provided in the packages.
Can you help to find a solution to this error?
Thank you again
In this case the case is significant and would cause it to break with your changes.
The issue is probably that it should have originally been 'Y-m-d h:n:s'
With your current settings it would be trying to set the date to: '2011-Jul-21 12:21:00', which would give a syntax error. See the meaning and case of the date settings on the page:
function.date.php
Try with the correct date string and let me know if you still get errors. If so, attach a current version of the page to your thread and I'll see if I can suggest a fix.
info266692
Dear Ray,
I have reverted to the code [php]<?php echo (date("Y-m-d h:m:s")); ?>[php] and i'm still getting this error: "Incorrect datetime value: '[php]2011-07-22 10:07:30[php]' for column 'login_date' at row 1".
The date is correct but it doesn't want to be registered in the database.
I have included a compressed file of the user_LogIn.php page for you to have a look at it.
Currently the in the column login_date, type datetime of the database there are dates stored from the previous version of the web site, shall I flush them away?
I'm testing the site on my local server in the Sydney time zone (Apache, PHP5.2.3, SQL) while the web host is located in the US via Perth in Australia. It may be possible that the incorrect datetime issue has to do with different time zones and daylight saving?
Thanks again for your assistance.
Alfredo from Oz
You should not be including the "[php]" references.
You should be using the value: <?php echo (date("Y-m-d h:n:s")); ?>
(notice also the 'n' should be used for the minutes 'm' is the month)
info266692
Dear Ray,
Whoops; you can see that I'm a bit green with PHP codings by the errors I'm making.
I did make those changes as you have suggested and now i'm getting a different error with the user_LogIn.php page "The login information provided is not valid. Please try again.".
This is the verification message in the Email Address field. I did shift the Update Single Record in the Server Behaviors right to the bottom of all the login codes and i'm still getting this error.
Do you have any other suggestions in how i can get around this error?
What about if we use the clients/index.php page to update the datetime record? However in this page there are no Form Fields to attach the Update Single Record coding.
Alfredo
I think the authenticate user server behavior may require a success field, so adding it to the client index page may be a better solution.
You wouldn't need to use a form field. You could just add the update server behavior and set the updated field value to: <?php echo (date("Y-m-d h:n:s")); ?>
There is no requirement to have or use a form when updating a record.
