Change in results from filtered recordset in FF....IE okay
Thread begun 7/19/2011 2:56 pm by md262153 | Last modified 7/21/2011 10:26 am by Ray Borduin | 2284 views | 3 replies |
md262153
I have an admin area that's been fine for a few years. A while back the client started having a strange problem and I finally got it replicated. It works fine in IE8 (and always has worked in IE) but doesn't work right in FF4 or FF5:
- Search for all UNAPPROVED records
- Select one of the records
- I have a button to APPROVE the record (it just changes one field using WADA Update).
- There's a button that sends an email to the person letting them know they've been approved.
- In IE, after doing this if you click on RESULTS you return to the recordset of all UNAPPROVED records (minus the one you just approved, of course) as you should.
- Recently (possibly FF4 and up?) when you click on RESULTS you get the entire recordset.
Any idea why this would be? It seems to be the Email button that's doing it. All that's doing is sending off an email and returning to the same page (with the same record no.) with the page showing a sentence to let you know the email was sent.
Any idea why it's behaving differently in FF?
Thanks,
Mad Dog
please send a copy of the page in a zip archive so i can inspect the code.
md262153
Thanks!
How do I send it so only you get it? Is there a support email address for you?
I'll create a support incident you can attach it to so that we are the only ones that can see it.
