repeat region
hi,
my repeat region doesnt work right. it always shows the text if the recordset is empty but it isnt :-(((
ShopItems.php
Cheers
hi,
ShopItems.php
Cheers
Just use a standard repeat region in DW instead of repeat selection.
Repeat selection only needs to be used when nesting inside an existing repeat region or when repeating for a set number of rows.
Repeat region should work for this without issue.
Add a repeated table to the page. It is a functional example of how that works.
