default location/infobox popup
Thread begun 7/18/2011 11:21 am by fogelde373550 | Last modified 8/26/2011 7:47 am by Jason Byrnes | 4363 views | 7 replies |
fogelde373550
For some reason I have one of 7 maps that has an info box that keeps poping up when the map opens. I cant figure out how to stop that.
Please help.
the easiest way to stop the info box from opening on page load is to enable driving directions, but dont enter a starting address.
fogelde373550
I would try that, but for some reason I can't open my map in dreamweaver anymore. Not sure why.
Isn't there a way to turn a default off?
edit the map js file ion the google_javascript folder, find the following code:
var fromAddress = {
enabled: false,
and change it to:
var fromAddress = {
enabled: true,
fogelde373550
var fromAddress = {
enabled: false,
and change it to:
var fromAddress = {
enabled: true,
I tried this, but now the map just shows one location (I have 8 addresses) and the map background is grey and it doesn't work at all.
See honda-test/
I also tried to edit the map in Dreamweaver, but now that doesn't work either. I just acts like I am doing a new map even though I hit edit??
please help.
Nature Photographer
Yes I have a simular problem with the "balloon window" showing when the page loads and anything I write into the window extends outside of the window.
I just learn't to live with it though!
have you tried this:
showpost.php?p=105263&postcount=4
