Continue Shopping doesn't
Thread begun 7/09/2009 9:46 am by john293655 | Last modified 7/13/2009 9:36 am by john293655 | 2251 views | 2 replies |
john293655
I'm really liking the eCart and this is pretty much the first time I've used it despite purchasing it over 6 months ago.
Everything seems to be going perfectly except for the continue shopping behaviour.
No matter what I do, it just stays on the same cart page. It does refresh and if I add an echo statement before the eCart-> redirect code, it shows fine. But no matter what I set the redirect string to - it just doesn't fire.
I could just put in a header redirection, but I figured the cart works for everyone else, so I should try to get it working as it should.
Any suggestions?
Here's my continue shopping snippet.
// WA eCart Continue Shopping
if (isset($_POST["eCart1_Continue_100"]) || isset($_POST["eCart1_Continue_100_x"])) {
$Redirect_redirStr="buy_music_test.php";
if (false && isset($_SESSION['WAEC_ContinueRedirect'])) {
$Redirect_redirStr=siteToPageRel($_SESSION['WAEC_ContinueRedirect']);
if ($Redirect_redirStr != "") {
//if I put my echo statement in here, it shows up fine.
$eCart1->redirStr = $Redirect_redirStr;
$eCart1->cartAction = "Continue";
anonymous
Do you have one of these?
// WA eCart Redirect
if ($BPeCart->redirStr != "") {
header("Location: ".$BPeCart->redirStr);
Might be your problem.
john293655
Odd that it's not added by default. I just used a standard header() call using the $eCart object seeing as I didn't have a $BPeCart as you do.
Anyhow, that didn't work so I just added the call to my continue shopping and checkout functions.
Sorry for the late reply.
John
Originally Said By: Stan
