Pro-Maps with SSL connection
Thread begun 7/15/2011 8:24 pm by ccdantas101117 | Last modified 7/16/2011 4:10 am by codamedia | 1489 views | 1 replies |
ccdantas101117
Does anyone use the Pro-Maps inside of a SSL (HTTPS) connection. I did try all solutions offered on google for SSL connection but seams not workin, and the IE keep send the annoying alert do you want o display, bla..., bla... BS...
Please anyone can help me with that?
Carlos
codamedia
That annoying alert comes up whenever the page is requesting outside data via "http://"
If this is only happening on a page with the map installed, then look for code that starts like this: (it's a much longer string, I am just posting the beginning)
<script type="text/javascript" src="http://maps.google.com/
Change the http:// to https://
As long as the google maps api runs from https it should work.
(note: if your page calls other 'outside scripts' via http, they would also have to be changed to https. (ie: flash, facebook, twitter, etc...)
Good luck!
