Help with my page :(
Thread begun 7/15/2011 12:21 pm by tuqan428258 | Last modified 7/18/2011 2:29 pm by Jason Byrnes | 2220 views | 3 replies |
tuqan428258
I am doing a simple one field test page (attached) to see if the Universal Email works.
I filled the field, attached one txt file and pressed "submit".
It seemed successful and there was no error message but 30 minutes later the email has not arrived!
What could be the problem, need help :(
thanks in advanced :)
UPDATE: I put a confirm page to make sure that everything is working fine but got this error:
Warning: require_once(../../../webassist/email/mail_php.php) [function.require-once]: failed to open stream: No such file or directory in /data/17/1/23/25/1838025/user/1994420/htdocs/adman/adman2011/Adman_2_Lang/swe/testingPHP.php on line 1
Fatal error: require_once() [function.require]: Failed opening required '../../../webassist/email/mail_php.php' (include_path='.:/usr/services/vux/lib/php') in /data/17/1/23/25/1838025/user/1994420/htdocs/adman/adman2011/Adman_2_Lang/swe/testingPHP.php on line 1
what is wrong again :(
there is no universal email code on this page, you have not applied the create email message behavior.
go to Insert -> Web Assist -> Create Email Message in order to apply the universal email behavior to your page.
make sure you are testing this functionality on your remote host and not testing locally, most local php servers do not have an SMTP server installed.
also check with the host to determine the correct SMTP sever address for sending emails thorough a php script.
tuqan428258
Thanks for the reply, I did all that, and got this problem, the site was uploaded to a remore server of course, how do I know if this code that you are mentioning exists ???
