SQL error - help. Please
Thread begun 7/14/2011 2:54 pm by doug.lemesurier305760 | Last modified 7/15/2011 6:57 am by Jason Byrnes | 2064 views | 3 replies |
I am receiving SQL errors after running DataAssist Wizard (DA 2.0.8).
After generating all pages, I test out the Search and Results Pages.
I run a search and the results page drops this error:
"You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'RELEASE 2, QTYOnHand FROM items WHERE ((VisitorBillName LIKE '%2%')) AND (ItemN' at line 1"
The thing is that I've made no modifications to the generated PHP at this point.
Any ideas?
the problem is being caused by using spaces in your database table column names:
RELEASE 2
when creating your database , you should avoid using spaces in the names, i recommend using the camelCase naming convention.
DataAssist
D'oh!
Thanks!
Doug
you're welcome.
