echo a variable on the blank.php template
Thread begun 7/14/2011 12:00 pm by Steve | Last modified 7/15/2011 8:48 am by Jason Byrnes | 4146 views | 7 replies |
Steve
Hello,
How do we write a variable that is available on the parent page POST that uses UE, in the template (blank.php)?
For instance, I am uploading an image and would like to take the value of:
$imageName = $WA_DFP_UploadStatus["WA_UploadResult1"]["serverFileName"]; ?>
which, shown here is assigned to the variable $imageName, and use this on the template page.
such as:
something <?php echo $imageName; ?> something else...
It seems the methods that load the Template are somehow removed from the variables that are present during the creation of the email object. I know that my uploading is done prior to the email as well as setting the same values to the DB. But I can't seem to write a var to the template page. Any reasons why and or how to overcome this?
use a session variable:
@session_start();
$_SESSION['imageName'] = $WA_DFP_UploadStatus["WA_UploadResult1"]["serverFileName"];
and echo the session in the template:
something <?php @session_start(); echo($_SESSION['imageName']); ?> something else...
Steve
Thanks Jason
you're welcome
Steve
Jason,
Why do you start your sessions with the "@" symbol?
I did not see this referenced in the PHP manual:
function.session-start.php
@session_start();
the @ symbol suppresses errors
in some instances the command:
session_start();
may result in a header already sent error.
to suppress that error, i use the @ symbol:
@session_start();
Steve
ok, I understand. Thanks for the detail.
you're welcome.
