Problems with Dynamic Voucher Codes
Hi all,
I have a site (www.piccolaonline.co.uk) who I am adding a dynamic voucher system for.
After following the pdf tutorial on adding a static voucher code and getting it to work, I then followed the method given by Jason (showpost.php?p=23007&postcount=2) to convert the voucher system to a dynamic one....but I can't get it to work!!!
If you go to the site and add some stuff to the cart and enter voucher code 'test15', you will see that the discount is not applied, but an echo of the recordset appears next to the voucher box - it shows the voucher code (test15) and the amount (0.15 for 15% as descibed in the method).
The sessions required have been added....but nothing happens!!!
Any ideas would be great...I've attached the cart page and a couple of others..
Thank you!
Martin
