Menu Editing in CS5
Thread begun 7/13/2011 1:02 pm by templemedia365477 | Last modified 7/15/2011 1:51 pm by Jason Byrnes | 2388 views | 3 replies |
templemedia365477
Menu Editing in CS5
I'm the last person in town to finally move to CS5 - there are some things to get used to in Dreamweaver.
I want to edit my first menu - where did the little eyeball go? How do I get back in? I've got 1.0.3. Thanks, ttt
Mike Perry
Originally Said By: templemedia365477
Make sure you have the Document toolbar visible -- it's there. . .
Then check "Invisible Elements", and click on the PHP tag beneath the menu in the preview. The Menu Edit window will display at the bottom. . .
templemedia365477
Menu Editing in CS5
Document tool bar is up and invisible elements is checked - please see attached screen shot.
I created this menu in CS3, where it remains editable...
turn the Script invisible elements on in the properties as well.
go to Edit -> Properties, in the invisible elements section select make sure to select Scripts
