Javascript errors not letting me add Univ Email
Thread begun 7/13/2011 11:40 am by roby258376 | Last modified 8/26/2011 6:54 am by Jason Byrnes | 4116 views | 9 replies |
roby258376
Hi there,
I have created a form, but when I try to add universal email functionality, either through CSS formbuilder or after through DW, I get the following error:
While executing timer in WAUE_Main.htm, the following JavaScript error(s) occurred:
At line 487 of file "C:\Users\Name\AppData\Roaming\Adobe\Dremweaver CS5\en_US\Configuration\Shared\WebAssist\FormBuilder\Controls\Scripts\WATrigger.js":
invalid array length
Need to know the solution please. I have already deleted the WinCache file.
please send a copy of the file you are trying to add universal Email to so I can look at the code.
roby258376
Good morning,
I am not able to upload the page as I get a message saying it's too large, can't paste the code into this message either, same problem. I also wanted to let you know that I am also getting the following error, when I add the form to any new page:
While executing findServerBehaviours in DynRadioGroup.htm, a JavaScript error occurred.
support103606
Same problem
It has been running fine for months now today it throws up the same error.
I removed the cache file, unnstalled and reinstalled but no joy.
What was the fix?
While executing timer in WA Universal Email.htm, the following Javascript error(s) occurred:
at line 449 of File
"....Commands\WA Universal Email.js":
Invalid array length
Im simply trying to add it to a blank php page with no other code.
What version of CSS Form Builder is installed?
Make sure to install the Version 2.0.1 support release 2 version that is avaiilbale for download from the download center.
if you have a previous version installed, make sure to uninstall the previous version from the extension manager before installing the newer version.
support103606
Versions in my account
The only version available is 1.0.2
Ok, Universal Email was not integrated into Form Builder 1, what version of universal Email do you have installed?
support103606
Current version: 4.0.1
