Delete Multiple Records in Repeating region
Thread begun 7/13/2011 7:32 am by Blikbrein | Last modified 7/13/2011 11:54 am by Jason Byrnes | 1868 views | 3 replies |
Blikbrein
I have a page with insert record behaviour. Once this is done, the page refreshes and a repeating table with a recordset containing the info inserted by the user in previous step is displayed at the top of the page. Sort of 'Fake' Ajax ;). Then I have a button at the bottom of the form to cancel the form request which means all the items inserted and displaying at the top which are in a table in the DB should be deleted when pressing this. This means a multiple record delete. when I want to insert this multiple record delete, data assist displays message which says I have to add repeating region server behaviour, which according to me is already done?
Please check my page code to see if I'm missing something. The records in the table that need to be deleted all have the same Requestnumber if this info helps at all.
there are no form elements in the repeat region, the multiple delete behavior requires form data to process the delete.
however, i dont believe you need to use the multiple delete behavior, you say:
why not use the single delete behavior and set it to use the Requestnumber column?
Blikbrein
Super Awesome! Thank you Jason. Didn't know the behavior was looping through the records to find all the chosen 'ID's'
you're welcome.
