Upload file trouble while updating record.
Thread begun 7/13/2011 1:01 am by BenoitBlouh | Last modified 8/04/2011 8:35 am by BenoitBlouh | 5938 views | 14 replies |
BenoitBlouh
I apologies for my bad english speaking.
I saw several times this problem on the forums but I can't fix it in my pages. I've tryed to follow this tutorial : dfp_da_insert_update_ht.pdf
When I replace the default input type to "hidden" instead of "text", the recorded name of my image stay good. That's a good point. BUT…
The problem is that when I try to update a record in my database with a new file field called "imageNEW" for example, the file doesn't upload, and it doesn't record the filename in the database.
If i just change the default input type to "file" instead as "text" it works only if I send another file. If I leave the field blank, the existant filename is erased from the database and the image cannot be displayed.
I don't understand what I have to do.
I've buy this extensions to help me developping websites by my own, but I can't…
And I need help :)
you have 2 problems in this page:
1) In the file upload behavior, you need to bind the default file to the image hidden form element.
In the server behaviors panel, double click the upload file server behavior to edit it.
On the second step of the upload file behavior, click the lightning bolt next to default file, from the forms collection select the image form element.
2) In the update record behavior, you need to bind the image column to the Uploaded Files (imageNew) -> Server file name variable from the bindings panel
In the server behaviors panel, double click the update record server behavior to edit it, on the second step of the Update record Behaor, select the image column, then click the lightning bolt next to value.
from the bindings panel, expand the Uploaded Files (imageNew) group, then select the server file name binding.
BenoitBlouh
Thank you Jason.
I've updated my pages.
// WA_UploadResult1_1 Start
$WA_UploadResult1_Params["WA_UploadResult1_1"] = array(
'UploadFolder' => "../folio/categories/",
'FileName' => "[FileName]",
'DefaultFileName' => "".$row_WADAcategories['image'] ."",
'ResizeType' => "1",
'ResizeWidth' => "880",
'ResizeHeight' => "",
'ResizeFillColor' => "#FFFFFF" );
// WA_UploadResult1_1 End
By doing this, when I select another image, its name is good recorded in the database. Goog thing :)
But i still have this problems.
1) The file is not uploaded
2) or its name disappears if i do not send a file in the file field.
I need some more help… :(
1) for the default file, you have bound to the image column from the recordset, you need to bind the default file to the file hidden form element
2) In the update record behavior, you have bound to the newFile element from the form collection, you need to use the Uploaded Files (imageNew) -> Server File Name.
3) To troubleshoot why the image is not uploading, add the following code at line 1:
error_reporting
(E_ALL);
change the following line:
$WA_redirectURL = "categories_Results.php";
$WA_redirectURL = "";
and add the following code just after the <body> tag:
<?php if($_SERVER['REEQUEST_METHOD'] == "POST") echo(WA_DFP_AllUploadsDebug()); ?>
BenoitBlouh
Ok…
It's done. Here is the result :
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /Volumes/LaCie3/htdocs/homdo_admin/admin/categories_Update.php:5) in /Volumes/LaCie3/htdocs/homdo_admin/admin/categories_Update.php on line 105
Status object: WA_UploadResult1
statusCode : -1
errorMessage :
clientFileName :
fileExtension :
serverFileName :
serverSimpleFileName :
serverDirectory :
contentType :
fileWasOverwritten :
fileWasSkipped :
fileWasRenamed :
fileSize : -1
isImage :
imageWidth : -1
imageHeight : -1
WA_UploadResult1_1:
clientFileName :
fileExtension :
serverFileName :
serverDirectory :
contentType :
fileSize : -1
imageWidth : -1
imageHeight : -1
BenoitBlouh
Here is the line 105 :
try changing the following code:
if(($_SERVER["REQUEST_METHOD"] == "POST") && (isset($_SERVER["HTTP_REFERER"]) && strpos(urldecode($_SERVER["HTTP_REFERER"]), urldecode($_SERVER["SERVER_NAME"].$_SERVER["PHP_SELF"])) > 0) && isset($_POST)){
if (isset($_POST["Update_x"])) {
for the error, see the following thread for detail on troubleshooting:
showthread.php?t=19285
BenoitBlouh
Ok. I've change the line, and the file is uploaded and the name stay recorded if i don't send another file !! Great !
Can we considered the problem solved ?
There is still an error :
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /Volumes/LaCie3/htdocs/homdo_admin/admin/categories_Update.php:5) in /Volumes/LaCie3/htdocs/homdo_admin/webassist/file_manipulation/helperphp.php on line 70
Warning: Division by zero in /Volumes/LaCie3/htdocs/homdo_admin/webassist/file_manipulation/helperphp.php on line 885
statusCode : 1
errorMessage :
clientFileName : IMG_0097.jpg
fileExtension : jpg
serverFileName : IMG_0097.jpg
serverSimpleFileName : IMG_0097
serverDirectory : /Volumes/LaCie3/htdocs/homdo_admin/admin/../folio/categories/
contentType : image/jpeg
fileWasSkipped :
fileWasRenamed :
fileSize : 62881
isImage : 1
imageWidth : 880
imageHeight : 660
WA_UploadResult1_1:
fileExtension : jpg
fileSize : 62881
imageWidth : 880
imageHeight : 660
isImage : 1
fileWasSkipped :
fileWasRenamed :
statusCode : 1
BenoitBlouh
Thank you very much for helping Jason !
