Intermittent add to database of SKU value
Thread begun 7/12/2011 2:32 pm by georgevargasa302189 | Last modified 7/13/2011 5:18 pm by Jason Byrnes | 1789 views | 3 replies |
georgevargasa302189
My ecart was working but I needed to add the parameter SKU to the database which was previously not needed.
1. Edited the eCart server behavior and added SKU column.
2. Deleted and re-added the Add to cart buttons to add the SKU link on the Purchase page
3. Edited the Checkout server behavior Ecart get contents from ecart1
4. Edited the Confirm page to change the save orderdetails server behavior to store the value
After all this everything seemed to work and the value was now being added to the database when an order was placed.
Then I noticed it didn’t work sometimes and the value was not being stored.
Now the situation is it works after clearing the browsing history and then placing an order. However the next time an order is placed the value is not added to the database, unless I clear the browsing history first.
I do clear all session values on the success page.
Did I miss a step, do I need to edit another page?
I have included the Purchase page with the add to cart buttons because I suspect it may be the source of the issue.
this does not make any sense, the browsers history should not have any impact on the information stored in the database.
have you tried this on other computers and/or browsers with the same result?
one think i wold try is to create a new php page, add a cart display manager to it to display the cart contents, in the cart display manager, go to the 2nd step, click the plus button and select all to show all columns in the cart display including the SKU column, use this cart display page for testing to make sure the sku is being displayed before going through the checkout process.
georgevargasa302189
Yes Thank you very much!!!!
Recreating the display page cured the problem.
interesting, glad to hear it foxed things for you.
