Repeating Table not inserting multiple Records
Thread begun 7/11/2011 6:51 pm by Blikbrein | Last modified 7/13/2011 12:02 pm by Blikbrein | 1689 views | 2 replies |
Blikbrein
I saw on one of the stickies that the 2.08 Release is supposed to solve the issue where only the last record of a repeating table is inserted with multiple record insert Server Behaviour, but I have that release and I am still experiencing the problem.
I am also not sure if the alternative content Regions are created incorrectly when I add the multiple record server behaviour, because I did not create them when inserting the repeating table region. Therefor I am not sure which dinamic fields to add since there are multiple repeating region options with their fields in turn
Relevant file is attached. Thanks
the problem is that there are 2 repeat selection behaviors added to this page.
I would start creating this from scratch again, add the checkbox to the page, then use a repeat region instead of a repeat selection.
Blikbrein
Did as you said and all sorted. Thank you. When do one use DA repeating table and when DW repeating Region? What is the difference between the 2?
