Pin Limit? Having problems displaying anything more than 20 - 30 pins.
Thread begun 7/11/2011 7:00 am by codamedia | Last modified 7/11/2011 12:55 pm by Jason Byrnes | 3871 views | 7 replies |
codamedia
My cache has write permissions, and it is generating fine, but there are occassions where I have many (30 +) pins, and the page will not load, nor will the cache get created.
Here is how I tested it.
1: Delete my "_promaps_geocache.xml" file from the server
2: Test a known result that shows 10 pins. This works great, "_promaps_geocache.xml" is re-created.
3: Test another known result that shows 10 - 20 pins. Works great, "_promaps_geocache.xml" has all the new entries added to it.
4: Try a known result with 30+ records, the map does not display, and nothing is added to the XML page.
5: Delete the XML page and try #4 again. The map does not display, and the cache page is NOT re-created.
For both #4 and #5, the page load is done almost immediately, but again, the map does not render and the cache is not created or added. It is as if Google is refusing to generate anything. Obviously, the cache cannot be created if Google does not respond the first time.
I came across this thread, and wonder if I might be having the same problem.
showthread.php?t=8702
I would love to know why this is happening, and how it can be corrected.
in 4 and 5 since the page load is done so quickly, I would suspect an error in the results set.
can you send a link where i can see the result of 4 to look into it.
codamedia
EDIT: Post removed.
can you send a copy of the page that loads the map please.
when i view source of your page when it displays the map, i can sere the following code:
/*wagmp*/
function WAMapRef(mapObj) {
this.obj = mapObj;
this.directions = false;
this.icons = [];
this.markers = [];
this.addresses = [];
this.points = [];
this.getPointByAddress = getPointByAddressFunc;
this.addressFailed = true;
return this;
function WAMapPoint(theMarker, theAddress, theIcon) {
this.icon = theIcon;
this.marker = theMarker;
this.address = theAddress;
return this;
function getPointByAddressFunc(value,attname) {
if (!attname) attname = "street";
for (var x=0; x < this.addresses.length; x++) {
if (eval("this.addresses[x]."+attname) == value) {
return WAMapPoint(this.markers[x],this.addresses[x],this.icons[x]);
return false;
function getHTTPObject(){
if (window.ActiveXObject)
return new ActiveXObject("Microsoft.XMLHTTP");
else if (window.XMLHttpRequest)
return new XMLHttpRequest();
else {
return null;
function searchCache(searchStr, zip) {
var xmlDoc = null;
if (window.ActiveXObject) {//IE
xmlDoc=new ActiveXObject("Microsoft.XMLDOM");
} else if(navigator.userAgent && navigator.userAgent.toLowerCase().indexOf('webkit') >= 0) { //webkit (Safari, Chrome)
var coordinates = '';
xmlDoc = getHTTPObject();
if(xmlDoc) {
xmlDoc.onreadystatechange = function() {
if(xmlDoc.readyState == 4) {
var x = xmlDoc.responseXML.getElementsByTagName("geocode_entry");
var geocode, id;
searchStr = searchStr.replace(/,/g, ''); //remove commas
for (i=0; i < x.length; i++) {
id = x[i].getAttribute("ID");
if (id == searchStr) {
coordinates = x[i].getElementsByTagName("geocode")[0].childNodes[0].nodeValue;
return coordinates;
xmlDoc.open("GET", "_promaps_cache/_promaps_geocache.xml", false);
xmlDoc.send(null);
return coordinates;
} else if (document.implementation.createDocument) {//gecko (Mozilla, Firefox, Opera)
xmlDoc=document.implementation.createDocument("","",null);
} else {
return '';
if (xmlDoc != null) {
xmlDoc.async=false;
try {
if(xmlDoc.load("_promaps_cache/_promaps_geocache.xml")) {
var x=xmlDoc.getElementsByTagName("geocode_entry");
var geocode, id;
return x[i].getElementsByTagName("geocode")[0].childNodes[0].nodeValue;
catch(err) {
return '';
return '';
function addToCache(fullAddress,zip, geocode){
httpObject = getHTTPObject();
if (httpObject != null) {
httpObject.open("POST", "google_javascript/promaps_geocache_php.php", true);
httpObject.setRequestHeader('Content-Type', 'application/x-www-form-urlencoded');
var entryId = fullAddress.replace(/,/g, '');
if (zip != '') {
fullAddress = fullAddress.replace(zip+',', '');
entryId = escape(entryId);
fullAddress = escape(fullAddress);
geocode = escape(geocode);
httpObject.send("sender=promapsforgoogle&action=add&entryId="+entryId+"&address="
+fullAddress+"&geocode="+geocode);
function wagmp_map_1() {
if(GBrowserIsCompatible()) {
if(!document.getElementById('wagmp_map_1')) return false;
var map = new GMap2(document.getElementById('wagmp_map_1'));
wagmp_map_1_obj = new WAMapRef(map);
map.enableContinuousZoom();
map.enableDoubleClickZoom();
map.addControl(new GSmallZoomControl());
map.addControl(new GMapTypeControl());
var geocoder = new GClientGeocoder();
var fromAddress = {
enabled: false,
street: '',
city: '',
state: '',
zip: '',
country: '',
full: ''
var icon_0 = new GIcon();
icon_0.image = 'google_javascript/images/traditionalflat_pacifica.png';
icon_0.shadow = 'google_javascript/images/traditionalflat_shadow.png';
icon_0.iconSize = new GSize(34,35);
icon_0.shadowSize = new GSize(34,35);
icon_0.iconAnchor = new GPoint(9,33);
icon_0.infoWindowAnchor = new GPoint(19,0);
icon_0.printImage = 'google_javascript/images/traditionalflat_pacifica.gif';
icon_0.mozPrintImage = 'google_javascript/images/traditionalflat_pacifica_mozprint.png';
icon_0.printShadow = 'google_javascript/images/traditionalflat_shadow.gif';
icon_0.transparent = 'google_javascript/images/traditionalflat_pacifica_transparent.png';
etc...
}</script>
<script type="text/javascript" src="http://maps.google.com/maps?file=api&v=2&key=ABQIAAAAzdubZVAMycelfiiPTYpVFBQPFfY7zKGhKSBgg4Uk6CKe9Mc3hhSAtsG1lpEwuqfqQ_TTP-avu9iPMQ">/*wagmp*/</script>
<div id="wagmp_map_1" style="width: 700px; height: 500px;"></div>
when it does not display the map all i see is:
there seams to be code in place preventing the map js from being built up in certain circumstances.
codamedia
The only difference on the two pages is the number of results. It's just one page, and the session value of the city is what populates the database.
Out of curiosity, how do I send you any files? I don't want them to be publically available (it is not my site to share).
codamedia
Jason,
Thanks for your help on this. I actually have figured it out.
This map page is included on the main page with web assist "framework builder" and it's a buffer issue. If I simply create a stand alone map page it works fine.
Thanks for the help.
ok, glad to hear it is working.
