Data Assist Multiple Files Upload not working
Thread begun 7/10/2011 11:11 pm by ijk76319396 | Last modified 7/11/2011 10:46 am by Jason Byrnes | 4142 views | 7 replies |
ijk76319396
I have a page that has multiple delete files as well as multiple upload files. I am using similar specs for both wizards however only the delete files option is working. I have attached my page. Is there something I am doing wrong here?
what exactly are you trying to accomplish with this multiple update? the way you have it configured will not update anything because there is no form element in place to change any of the data.
ijk76319396
I don't want to update it. I forgot to take that out so the update is not supposed to be there. I am trying to insert multiple records that is what is not working. I have saved a revised copy of the file.
i still dont get what you are trying to do.
all you have to insert is a checkbox, that contains a value already inserted to the database?:
<input type="checkbox" name="check_<?php echo $RepeatSelectionCounter_1; ?>" id="check_<?php echo $RepeatSelectionCounter_1; ?>" value='<?php echo $row_rsPH["ID"]; ?>'/>
this does not make any sense.
it also does not look like you have made any bindings on the second step of the multiple record insert for fields that should be inserted.
ijk76319396
What I am trying to do is take values from the rsPH recordset and put them into a database table. The values from the rsPH recordset are values from another table in my database.
ijk76319396
I have attached a screen shot of what I have entered for the second step values.
the insert multiple behavior does not support recordset bindings directly.
add hidden form elements to the repeate region form, bind those hiden elements to the recordset rows, use those hidden form elements in the multiple insert behavior.
