time out if someone walks away
Thread begun 7/08/2011 11:11 pm by un33k9309513 | Last modified 7/12/2011 9:13 am by Jason Byrnes | 1418 views | 1 replies |
un33k9309513
1. I am using SA for logging in and securing pages. How would I set a timeout if a user walks away from their computer so they are logged out automatically?
2. How else can I make the pages more secure in addition to page access with SA?
3. I also had an issue with SA messing up my files by adding line breaks and random code into mySQL table associated with the files I was trying to protect with SA page access. Then I tried to reload a backup of the same files with DW CS3 and still had the same issue so some of my webpages where not showing, and it added some random text to mySQL table, each line is in a different column on the same table row though. [] = a small box
if(!WA_Auth_Rule_Passes("administrator")}{
[]WA_Auth_RestrictAccess("../accessdenied.php");
I had 12 rows of this same code in mySQL, never had this issue before, is this a known issue? How can I prevent this?
thanks
1) Session time out is set through the php.ini file, see the following web master world post:
12812.htm
2) security assist will only protect your pages from unauthorized web access by username and password. server security is a whole other subject though that goes beyond the scope of this forum.
3) I have created a support ticket so we can look into this issue further.
