Check if skill is >0
Thread begun 7/08/2011 2:59 pm by Cologne | Last modified 7/08/2011 3:14 pm by Jason Byrnes | 1143 views | 1 replies |
Cologne
hi,
is it possible to check (in authenticate user) if a number from the table is >0.
i tried to put in >0 in the value, but that does not work.
see attached image.
Denis
No, the authenticate user only supports equals comparisons.
you would need to store the skill column in a session (on the third step of the authenticate user behavior) and create an access rule that checks to make sure the skill is > 0
