remove spaces or encode [FileName] during DPF upload
Thread began 7/08/2011 9:14 am by Nathan69474 | Last modified 7/08/2011 3:43 pm by Jason Byrnes | 2623 views | 3 replies |
Nathan69474
Hi
I’m using both Digital File Pro and Data Assist, to upload and insert an image into a db field
... works perfectly but I want to tweak the uploaded file name and incremental file names.
Is it possible to encode the [FileName] and [ExistingFileName]_[Increment] to remove or replace space with + sign during the DPF naming process
eg...
to: test+image+upload+with+space+in+name.jpg
nathan
Extra information, but not necessarily to read all ....
I have already tweaked the file name wizard entry to output as
wizard code ...
<?php echo ((isset($_POST["imgName"]))?$_POST["imgName"]:""); ?>_[FileName]
... and having a hidden form field in the upload file form.
ie <input type="hidden" name="imgName" id="imgName" value="<?php echo urlencode($row_rsInfo['text1']); ?>" />
Where rsInfo is my recordset and text1 is the gallery name.
Gives the upload file name of ...
I would like it to rename as ...
And incremental replacements as ...
you would not want to force the plus signs intothe server file name, that is not a valid file name.
you can remove spaces from the file name though by editing the webassist/file_manipulation/helperphp.php
change line 81:
$baseFileName = preg_replace('/\.[^.]*$/', '', $uploadedFile["name"]);
$baseFileName = str_replace(' ', '', $baseFileName);
Nathan69474
works a treat ... thanks Jason.
... have also corrected the + signs for no space in the gallery name part of the file name.
thanks
nathan
you're welcome.
