Embedding videos using HTML Editor
Thread begun 7/07/2011 12:10 pm by k.s.99646 | Last modified 7/14/2011 3:04 pm by codamedia | 4011 views | 3 replies |
k.s.99646
I'd like to allow a user to be able to embed a video on a page using the HTML Editor. It doesn't look like that's built-in functionality. Could it be added?
no the only media supported buy HTML is images and Flash.
k.s.99646
Embedding video
I was told by WebAssist that it's possible with some tweaks, and that I should ask in the forums about it. A joke, perhaps? If anyone's been able to make it possible to embed video using the HTML Editor, I'd sure love to hear about it.
codamedia
What kind of videos are you trying to add?
I have found that embedding "You Tube" vidoes is extemely easy. Just copy the code from You Tube and paste it in the editor where you want it (in CODE VIEW).
I have also had success uploading Windows Media files then manually writing the code. If you know how to write the "embedding code" then it is quite easy from Code View.
Keep in mind, if you allow JavaScript to be entered then this should only be done in a locked down admin area. Don't ever allow a site visitor this type of access (ie: forum posts, blog replies, etc...) as someone will hijack your site with XSS!
Good luck.
