Limit Download Count
Thread begun 7/07/2011 10:54 am by hbibizadeh396670 | Last modified 7/08/2011 12:35 pm by hbibizadeh396670 | 6733 views | 10 replies |
hbibizadeh396670
Is there a way of limiting the amount of downloads in my download centre.
For example, when a user has paid for digital goods, it appears in their download centre,
How Can I limit the number of times a digital file can be downloaded?
Such as, 5 downloads per purchase
you need to add a download count to order details table, set the default value for the new download count column to 0
in the download file server behavior, set the download counter section to use the new download countcount column, this will increment that comlumn each time the file is downloaded.
make sure that the new download count column is returned by the recordset on the download cewnter page with the rest of the order detaisl table.
then add an if statement around the download button to only show it if the download count is 5 or less:
<?php if($row_recordsetName['downloadcount'] <= "5") { ?>
<download button>
<?php ?>
hbibizadeh396670
Thank for the help,
I have made the download count work, but the show if dose not work for me.
I have a small message beside my downlaod button showing the number of downlaods and I have exceeded 9 downlaods when the limit is 5.
And the downlaod button still appears.
Here is my code
<?php if($row_WADAsiteezyecorderdetails['downloadcount'] <= "5") ?>
</p>
<p><?php echo $row_WADAsiteezyecorderdetails['downloadcount']; ?> Out to 5 Downloads Used</p>
<form id="form1_<?php echo $row_WADAsiteezyecorderdetails['ProductID']; ?>2" name="form1_<?php echo $row_WADAsiteezyecorderdetails['ProductID']; ?>" method="post" action="">
<input name="hiddenField2" type="hidden" id="hiddenField2" value="<?php echo $row_WADAsiteezyecorderdetails['ProductLocation']; ?>" />
<input type="submit" name="download2" id="download2" value="Download" class="dbut" />
</form>
<?php } ?>
Hope you can help
this code has a syntax error:
it should be:
<?php if($row_WADAsiteezyecorderdetails['downloadcount'] <= "5") { ?>
hbibizadeh396670
I am now getting a syntax error here
mysql_free_result($WADAsiteezyecorderdetails);
mysql_free_result($Settings);
not enough detail.
when report an error, you need to include the exact text of the error message and a copy of the page.
hbibizadeh396670
Parse error: parse error in C:\wamp\www\Site\DigitalGoods\download_center.php on line 494
you have an if statment at line 386:
<?php if ($totalRows_WADAsiteezyecorderdetails > 0) { // Show if recordset not empty ?>
that does not have a closing tag.
change line 431;
<?php if ($totalRows_WADAsiteezyecorderdetails == 0) { // Show if recordset empty ?>
<?php } ?>
hbibizadeh396670
Yep it works.
Could you just tell me how to use a show if to show a message?
Download limit exceeded.
If the download has been used over 5 times and the button does not show.
<download button>
<?php } else { ?>
to many downloads
<?php ?>
