Creating a composite field
Thread begun 7/06/2011 1:25 pm by john70964 | Last modified 7/13/2011 2:47 pm by john70964 | 7099 views | 11 replies |
john70964
Can anyone say how I create a composite field in mysql.
I have two fields, one defaults to the string images/ and the other contains the image name.
I wish to have a composite field images/imagename
I can use navicat if needed.
Many thanks
John
the image path should be set by the database, it should be set on the page that will display the image since the path will be different based on the where the page is in the site in relation to the where the image is.
when you display the image, use the image columns from the recordset and add the path before it:
<img src="images/<?php echo $row_recordsetNmae['ColumnName']; ?>" />
john70964
Thanks Jason,
Where you write"the image path should be set by the database" should this be
the image path should NOT be set by the database?
In the past when using access I could create a composite field in an access query. It seems this is not possible with MySQL?
yes, sorry, it have read read:
it _is_ possible to concatenate 2 fields in the query using the CONCAT() function:
sql-concat-in-mysql.aspx
but not recommended for what you are trying to accomplish
john70964
Hello Jason
Thanks for the info regards the database.
I am trying to get a dynamic image to show but no luck so far.
I checked the image exists in c:\xampp\htdocs\FB_PHP\images The text fields show correctly.
I wonder if you can see if there is a mistake in the code at ['products.image190)']
I did insert a beginning (
I also tried it without the )
Bit it made no difference can you see any mistakes?
Regards
John
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <title>Untitled Document</title> </head>
<body>
<p>List Page</p>
<?php do { ?>
<p>&nbsp;&nbsp;&nbsp;<?php echo $row_rsProducts['image190']; ?>&nbsp;&nbsp;&nbsp;<?php echo $row_rsProducts['ProductName']; ?>
&nbsp;&nbsp;&nbsp;
<img src="images/<?php echo $row_rsProducts['products.image190)']; ?>"/></p>
<?php } while ($row_rsProducts = mysql_fetch_assoc($rsProducts)); ?>
</body>
</html>
mysql_free_result($rsProducts);
the image path is relative to the document.
using this source:
will only work if the document exists at the same level as the images folder, in other words if the images folder is at:
that src path:
will only work if the document is in the FB_PHP folder
if not, you need to adjust the image path.
john70964
The code seems OK but the images do not show.
Localhost seems OK please see image.
Perhaps you can see where I am wrong?
John
Code is:
<?php require_once('Connections/Conn_FB_PHP.php'); ?>
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
$theValue = ($theValue != "") ? "'" . doubleval($theValue) . "'" : "NULL";
break;
case "date":
break;
case "defined":
break;
return $theValue;
$maxRows_rsProducts = 10;
$pageNum_rsProducts = 0;
if (isset($_GET['pageNum_rsProducts'])) {
$pageNum_rsProducts = $_GET['pageNum_rsProducts'];
$startRow_rsProducts = $pageNum_rsProducts * $maxRows_rsProducts;
mysql_select_db($database_Conn_FB_PHP, $Conn_FB_PHP);
$query_rsProducts = "SELECT * FROM concat_test WHERE ProductCategoryID = ProductCategoryID";
$query_limit_rsProducts = sprintf("%s LIMIT %d, %d", $query_rsProducts, $startRow_rsProducts, $maxRows_rsProducts);
$rsProducts = mysql_query($query_limit_rsProducts, $Conn_FB_PHP) or die(mysql_error());
$row_rsProducts = mysql_fetch_assoc($rsProducts);
if (isset($_GET['totalRows_rsProducts'])) {
$totalRows_rsProducts = $_GET['totalRows_rsProducts'];
} else {
$all_rsProducts = mysql_query($query_rsProducts);
$totalRows_rsProducts = mysql_num_rows($all_rsProducts);
$totalPages_rsProducts = ceil($totalRows_rsProducts/$maxRows_rsProducts)-1;
?><!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd">
<html>
<head>
</head>
<body>
<p>List Page</p>
<?php do { ?>
&nbsp;&nbsp;&nbsp;<img src="images/<?php echo $row_rsProducts['products.image190)']; ?>"/></p>
<?php } while ($row_rsProducts = mysql_fetch_assoc($rsProducts)); ?></body>
</html>
john70964
It seems the imagename is not being found
source code in FF shows
<p>842|cav0022_190.jpg|Class Roberto Cavalli long black evening dress|
<img src="images/"/></p>
<p>953|cav0023_190.jpg|Class Roberto Cavalli black sequinned cocktail dress|
I edited the html code in FF and placed the image names in the correct position. The images showed OK
Please see pic attached.
I cannot see why the image does not show.
the code that ios displaying the image name:
is not the same code you are using in the image src:
the image tag:
should be changed to:
<img src="images/<?php echo $row_rsProducts['image190']; ?>"/>
john70964
Thanks Jason
"should be changed to:
<img src="images/<?php echo $row_rsProducts['image190']; ?>"/>"
Yes I understand this now.
However it did not solve the problem
See image image190 Firebug
The images I believe are located correctly
See image190 Localhost
The recordset shows image190
Dreamweaver seems to run very slow in php could this be associated?
